In order to achieve that you can go in the“Updater” page and enable the “Check for updates using Advance Updater” option.
You can create a manual execution update(from application, using a shortcut) or an automatic one which is accomplished using Windows Task Scheduler tool. Also, you can
Integrate the Updater in your application.
When launched, the Updater checks if a newer version of the application exists by using a predefined criteria.
You can take a look on our
“Using The Updater” tutorial.
