KRedman
Inconsistent results with New Custom Action Wizard
I'm trying to create a custom action to run a .bat file, but I'm not having any luck. These are some results using the exact same process:
This page that I keep getting referred to doesn't seem to be relevant to the Custom Actions anymore. Or am I just doing it wrong?
Re: Inconsistent results with New Custom Action Wizard
Indeed the Launch a CMD or BAT file article from our user-guide hasn't been updated to the new user interface that has been implemented in the latest version of Advance Installer.
The <Ai_custac>viewer.exe is automatically called by the application, but it is not displayed to the user anymore.
Now, the “File To Launch” field must contain the path to the file you want to launch (e.g. [#test.bat]), but the “Command Line” field is not mandatory.
The “Working Directory” field is also optional depending on your scenario.
KRedman
Thanks.
You're welcome.
