mbilet
Selection Tree issue
I have a minor issue with "Selection Tree" control. I use it in feature selection dialog and It consists of two items(features).
Selection Tree.png (5.82 KiB) Viewed 6541 times
The question is: is it possible to open feature context menu
Selection Tree1.png (8.57 KiB) Viewed 6541 times
and enable or disable feature using only keyboard?
I tried different key combination like Up, Down, Left, Right, Alt+Down, Alt+Up, Alt+Left, Alt+Right ... , but wasn't successful to open this menu for selected feature.
Environment:
- Win 7;
- AL 10.1
Mykola
Re: Selection Tree issue
Indeed, this seems to be an Advanced Installer issue when the “Enhanced User Interface” is activated. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
As a workaround, you can go in the “Theme” page >> “Settings” tab and deactivate the “User Interface”. Now you can use the “space” shortcut keyboard to open features context menu.
mbilet
Could you tell me which "AI" version will include the fix for this issue?
Mykola
A fix will be available in the next version (10.4) of Advanced Installer which will be released in August.
This was fixed in version 10.5 of Advanced Installer released on September 02, 2013.
