digitalrinaldo
Java Installer Dialogs 10.2
I started our use of the AdvancedInstaller with the 30 day trial. It was upgraded to a Java License. I mention that so the Environment is understood.
There are two questions about what is or is not included and why the UI shows items that are not enabled or not possible to use.
1) I would like to use the action to send user data to the server. I am unable to get the post to occur. The documentation indicates that I should perform some additional steps which I am not presented. http://www.advancedinstaller.com/user-g ... -info.html Do I need to upgrade to the next License Level. A second question on this topic is if multiple selection works on the selection boxes. In some cases I want to select 10 items to send do I have to select each then click ok and then add. Just a small issue.
2) We would like to change some of the colors on the dialog in the attached image from green to some other color, the bar at the top. We would also like to remove the user selection for where to install. Are both of those possible and if so do we need the next level of product for that?
The yellow area is the color
Re: Java Installer Dialogs 10.2
If you want to create a new dialog in order to collect user input information, then you need to use our "Dialog Editor" feature which is available only in an "Enterprise" or above license type.
I'm afraid I don't fully understand what you mean. Can you please give us more details about this (maybe exemplify)?
Please take a look on our "Custom window chrome" thread which debates a similar issue. Also, in order to achieve this you need at least an "Enterprise" license of Advanced Installer.
In order to achieve this using a "Java" project type you should remove the "InstallDlg" dialog from your projects. For example, you can proceed like this:
- Go to "Dialogs" page and add "WelcomeDlg" dialog.
- Delete the "InstallDlg" dialog.
- Build and run your project.
If you don't want to remove the "InstallDlg" dialog within your project dialogs, then you can disable the "FolderEdit" control from "InstallDlg". Also, in order to achieve this you need at least an "Enterprise" project type.
digitalrinaldo
Daniel wrote:Hello,
We have purchased the Enterprise License and I am still not able to do the following. I looked at the documentation for adding a user dialog and I was unable to accomplish my desired approach. When a user accepts the license I would like to capture the User Data without additional dialogs.
When one selects custom actions and picks user data, there are a number of items one can select from the list box. If you want to select all of them for testing and debugging you would have to click on each one and then add and then ok and then go back. That is an awful lot of mouse clicks. I was expecting standard multiple selection behavior. Is there some other way?
