jlarosa
Installing for all Users
I have tried to use the "Permissions" tab in the folders options for the installer, but i'm still having issues with it.
When i run the installer on a computer that is part of a domain, it keeps looking for a domain account called "users" or "everyone" and it fails.
How can i make the Installer give an option to Install "Full Access" to ALL users, regardless of them being local or via the domain.
If anyone could help, that would be great.
-Jonathan
Re: Installing for all Users
I'm not sure why you encountered this behavior. Can you please add, using our "Permissions" tab, "Full Control" permissions for "Everyone" users group and see if the behavior still persist?
jlarosa
Installer Error.jpg (543.54 KiB) Viewed 4252 times
I got the same error, I'm including screenshots.
Please notice that in Windows Installer only Everyone and Administrators are the same for all languages and all other account names should be localized. Advanced Installer localizes these groups and stores their values in properties.
In the following article it is explained the method we used to localize them.
If you use a a specific language you can take a look on the following thread which debates a similar issue.
If the behavior persist, can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
