Morantex
Cannot add registry information
Hi;
I'm trying to get my installer to add some information to the registry but it is being ignored it seems.
I'm trying to add key name 'Morantex' beneath HKLM\Software\Microsoft\.NETFramework\AssemblyFolders
Then within the new key (Morantex) adding a simple (Default) value that points to a folder in the installation.
This looks fine in the AI IDE - the new key 'Morantex' has "create if absent" and "delete if present" set (the parent keys do not because they (should always) pre-exist).
When I run the installer it runs fine but the new key and value are never there - Ive checked spellings, refreshed regedit etc but cant see any obvious problem - what am I doing wrong?
Hugh
The Microsoft documentation for this can be found here:
http://support.microsoft.com/kb/306149
Morantex
Re: Cannot add registry information
While trying to understand this issue, I saw the menu icon "Add key from registry" and added HKLM\Software - once I clicked OK it took ages and ages - it would be nice to be able to cancel this operation once started as I did not intend to add that large a subtree....
Morantex
OK I'm getting somewhere - I will update this thread once I make a few changes....
OK this is resolved - the keys were being added - but I completely forgot about the Wow6432Node !!
Thx
Hugh
Hello Hugh,
I've added this improvement on our TODO list and maybe it will be implemented in a future version of Advanced Installer. Thank you for your suggestion.
