matt.luthi@gmail.com
Testing of SQL connection *crashes*
I am running a DB creation script on install/upgrade. The setup works fine on 4 out of 5 machines. 2 of the machines are both Win7-x32. The machine that fails (Win7-x32) has successfully installed with the DB connection test working but now on upgrade, I am getting this error when I click "next" on the DB connection settings screen.(check screen shot with error message). Does not look to me like this is a set up error, more like an environmental issue on the machine. Perhaps you have seen it before?
Cheers,
Matt
Re: Testing of SQL connection *crashes*
Hello Matt,
I'm not sure why you are encountering this behavior. Can you reproduce the behavior on multiple Windows 7 x86 machines? If so, can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
Also, it would be useful if you can isolate the behavior in a sample which always reproduces the behavior.
Hi Daniel, I've sent both files to your support email address.
Matt
