We have an unusual problem - we need to 'manually' copy a native DLL into a folder in the raw file system where a GAC component also resides.
The problem is that the installer's GAC registration seems to take place after all files have been copied to the target system, but when an assembly is registered into the GAC any existing version (which includes the raw file folder it sits in) is deleted.
FYI an assembly ASMBLY with version VERSION and public key token TOKEN gets placed into the GAC file system in a folder named: Windows\assembly\GAC_MSIL\ASMBLY\VERSION__TOKEN
This is hidden from view normally because Windows file explorer displays all this differently, but it is how its structured if you view the raw file system (eg this registry tweak lets you see it raw).
So my question: is there a way to defer a particular file copy step until AFTER any assemblies have been registered?
or
Is it possible to create a custom file copy step that gets performed at the end of the installation (but when it is still running in elevated mode).
