lars.ugleberg
Registry keys are not created during installation
I have created a fairly standard installation, which comes with two standard keys intended to be created in the registry. The first few times I ran the installation, the keys were created, but the specified values were not added to the keys. However, the last few times I have tested the installation, the keys have not even been created. What am I doing wrong?
setup.aip
My setup project file
(48.14 KiB) Downloaded 342 times
Re: Registry keys are not created during installation
I've tested your project, but it worked well to me. Please keep in mind that on a 64-bit Operating System the registry entries are stored in the "WOW6432Node" when a 32-bit package is installed.
lars.ugleberg
Thanks for the welcome, and for your quick response! I was not ware that 32-bit apps were placed under that node! Just checked, and it works fine - just as you said!
lars.ugleberg
Eusebiu wrote:I've tested your project, ...
By the way, did you get a warning (1910) about not being able to remove the shortcut? This is my next little hurdle, so if you have any advice about this, please let me know!
Lars
Hi Lars,
I didn't get that warning because I removed the files from your project in order to be able to build it (the project cannot be built with missing resources).
However, I remember that this problem was very much debated in the past and we finally found that there was a Windows problem. You can read about this in the Warning 1910. Could not remove shortcut thread.
lars.ugleberg
Hello, thanks again - the previously suggested solution involving using a custom action works perfectly!
Lars
