digitalrinaldo
Previous Version not being uninstalled in some cases
I have checked the uninstall previous version
I run the installer and I get a message about previous versions being there.
Re: Previous Version not being uninstalled in some cases
Using ”Uninstall a package with the same version(if found)” option for the Bootstrapper options should
uninstall the previous package if it has the same product code and product version as the current package.
Can you give us a straight pattern which reproduce the behavior?
