ElyCyan
Untranslated String in Russian Select Installation Folder
In our Russian installer, everything is translated nicely except for the 'Cancel' button in the browsing window for selecting an installation path:
Screenshot of the untranslated cancel button
I cannot find this in my Russian translation dictionary. Am I missing something? How do I fix this? (Hopefully this isn't a Windows Installer bug)
Re: Untranslated String in Russian Select Installation Folde
I'm afraid this is our default behavior. Also, unfortunately there is no workaround that you can use for the moment.
This dialog is only displayed when the enhanced user interface is enabled.
This is the system open file dialog customized for selecting a folder. That is why only the Folder path label and [Select folder] button are changed. The [Cancel] button and any others remain untouched.
The [Cancel] button is using the system language. So, if you use an operating system in Russian language the related button will be properly translated.
We will also translate the [Cancel] button in a future version of Advanced Installer. Thank you for your suggestion.
ElyCyan
Thanks you Dan, that's very good to know. I'll make a note of it!
This improvement was added in version 10.7 of Advanced Installer released on November 11, 2013.
