digitalrinaldo
Enterprise 10.3:Unable to locate a resource that is missing
I changed the location and names of some resources. When I build I am told the resource is missing. When I try to locate it in the table editor I can't find it. Normally locate points to the exact reference. How do I find the resource. It appears to be a dangling resource that may be in the .aip file but it is not appearing in the UI in a way that allows me to remove it.
Re: Enterprise 10.3:Unable to locate a resource that is miss
It seems that the path to the EULA file is not specified correctly. You can go in the Dialogs page, select the "LicenseAgreementDlg" dialog and set a correct path for the EULA file.
Also, in the Table Editor page you can find it in the "Control" table at the following row:
LicenseAgreementDlg        AgreementText          ScrollableText
Let us know if this helped.
digitalrinaldo
I had been using the two licensing approaches and both were using the same file. When I deleted the other one. The Eula was left in the config. I had to remove it manually by finding it. The suggestion above was not required because it was the correct the file. There were actually two references. This probably is not a common use case but it appears that turning off features leaves residue in the config at times.
Thank you for sharing with us your solution, I'm sure it will help other users in the future. I'm glad you got this working.
