minnumathew
Edit warning message
Hi
I am getting the following warning message while I upgrade my application from version 1.0 to 2.0. Currently I need to edit this warning message. Could you please advice me the steps which I need to do for editing this message?
Re: Edit warning message
In order to achieve what you want you can go in the Table Editor page, select the "Error" table and edit the message related to the error "1607".
Let us know if this helped.
minnumathew
Thank you so much for the reply
Is it possible to edit the process name listed in the listbox? Instead of the current process name, I need to display the appplication name in the listbox. Could you please advice me on this?
Minnoo
Hi Minnoo,
I'm afraid that the process name cannot be edited, however, as a workaround, you can use the solution discussed in the Custom Launch Condition Help thread.
minnumathew
This is what I actually expected and it worked for me.
Thank you Eusebieu.
