sonu
Request for Spanish (Chile) Dictionary (.ail)
HI Support Team,
version : Advanced installer 9.8
May i have Spanish (Chile ) Dictionary (.ail) file for building a dedicated conversion
If i go for Translations -->
In language selection ---> if i select dedicated Spanish (chile) it shows "Advanced installer has no translation for this language so it will attempt to take the strings from the dictionary to the closest related language "
In the default string it shows empty values through out the column.
Please help me on this we are facing very critical issues...
With Regards,
Pradeep.
Re: Request for Spanish (Chile) Dictionary (.ail)
Hi Pradeep,
Unfortunately, we do not have translations for all the languages displayed in the Translations page, only for those that are displayed when the "Selected or known" option is chosen in the combo box from the upper-right corner of the page (if an untranslated language is selected it will also be displayed).
In this case, you can go in the "Default Strings" tab and translate the strings by yourself, otherwise the "Spanish (Spain)" language will be automatically selected.
sonu
Thanks for your replay..
A small quick question..
I have changed the wizard titles and Description as per my need in (Development machine) which is in us language . Once i choose the Spanish..in translator its converting the default values which are given by tool (as a predefined Titles and Description)..
other question: I need my setup to support based on the OS language... but the setup should be the One.
With regards
Pradeep.
Eusebiu wrote:Hi Pradeep,
sonu
other question: I need my setup to support based on the OS language... but the setup should be the One.(MY media type: Resources inside the Exe)
With regards
Pradeep.
Hi Pradeep,
In order to go around this problem, you can go in the Dialogs page, select each title and description you changed earlier, then, in the "Properties" pane click, on the flagged button from the right of the "Display -> Text" field and choose the "Never translate this string" option.
In order to achieve this you can go in the Translations page, "Languages" tab and use the following settings:
  • Create only a multilingual package
    Automatically use system language for installation
Also, as you mentioned, you can choose "Single EXE setup (resources inside)" in the Media page.
sonu
HI,
In the First case : I modified the Text and Description (US), need to change the modified text into Spanish ..
REsult: It display's modified the Text and Description (US).Not shows Spanish text (US language is not converted to the Spanish (chile)).
Default strings modification is not allowing..to modify the value.
With Regards,
Pradeep.
Please keep in mind that the custom Text and Description (US) are not automatically translated to Spanish, you can translate them in the Translations page, "Default Strings" tab (you can find end edit their "Localization ID" like in the attached image).
Are you telling that you are not allowed to modify them like shown in the attached image?
Default Strings Tab.png (70.66 KiB) Viewed 29074 times
sonu
If possible can you tell (XXXXX.ail) is used or we can use an new (XXX.ail).
With Regards,
Pradeep
sonu
HI Team,
I got ur answer...its happens only if we select spanish..its shows a message (nearest Localization is preferred ) that case it shows an option ot edit the Default localization...
If i select spanish (<AI_USERDICTS>ui_es.ail) file si getting added , can you tell what it is ?
Where it is located...? if i found such files ..how to edit the default localization...
Please revert to me with supported answer
With Regards,
Pradeep.
Hi Pradeep,
The "AI_USERDICTS" is a path variable and the "ui_es.ail" is the name of the Spanish dictionary.
The "AI_USERDICTS" value is "C:\ProgramData\Caphyon\Advanced Installer\dictionaries", you can also find it by going to Options->Path Variables like in the attached image.
In order to edit the dictionary you can follow the Translate dictionary tutorial.
Path Variables.png (21.98 KiB) Viewed 29061 times
