sonu
static text on Installer wizards
Hi Support,
Our requirement is to change the static text that get displayed on Installer wizards by using some configurations file i.e. Before launching the installer, can we use any configuration/properties file for read and write the text on the wizards rather than displaying the static text by setting in the properties. Is it possible to do it in the advanced installer?
Attached the installer wizard static text that has to be dynamically.
Please let us know your suggestions.
Regards
Sony
dms
Re: static text on Installer wizards
Hi Sony
If you have an enterprise licence for Advanced installer then you should be able to do what you want with ease (just go to the dialogs section where you could set the text to a custom property, however I suspect that if you only have a professional licence you will not be able to achieve the customisation that you want.
Dom
Hi Sony,
The answer Dom posted above is correct. You can go in the Dialogs page, select the static texts you mentioned and in the "Properties" pane, "Display -> Text" field use a custom property (i.e. [MY_DESCRIPTION]) that will be set according to your configuration file. You can populate this property using your own custom action above the "Wizard Dialogs Stage -> Path Resolutions" action group.
sonu
Hi Support,
We do have the enterprise version of advance installer 9.8. Updated few key pair values in the "ui_es.ail" file available in "C:\Program Files\Caphyon\Advanced Installer 9.8\dictionaries". After doing this, I have opened the advanced installer project file and getting an xml corruption error. Can you please provide detail steps to implement this requirement.
Sony
sonu
Hi Eusebiu,
I need to write the values from the configuration file to the wizards before launching the installer but not from the custom action. I was able to achieve by using vb script.But I tried to update the keys and values directly in the "ui_es.ail" file available in "C:\Program Files\Caphyon\Advanced Installer 9.8\dictionaries" folder location. By doing this, advanced installer is unable to identify the modified "ui_es.ail" file and unable to open the project file. hw can we do this?
Regards
Sony
Hi Sony,
The wizards text will be updated if the custom action is executed above the "Wizard Dialogs Stage -> Path Resolutions" action group as I mentioned in my previous post.
I'm not sure why the error is thrown, but maybe something was not correctly changed in the dictionary file. However, I think that it is more simple to edit the dictionary in the Translations page, "Default Strings" tab where nothing can be broken.
