eshiva
Problem when using in VISTA
i had created a MSI package and which is working fine in Win7. But in VISTA the background image is not showing and I had added a custom action of terminate process when uninstalling my product. This action is also not working in VISTA. What is the problem. Is this tool has any OS specific limiations.
Shiva
Re: Problem when using in VISTA
Hello Shiva,
We are not aware of such an issue. Can you please test on another clean machine and see if the behavior still persist?
If the behavior still persist, can you please tell us the version of Advanced Installer and the Operating System(32/64 bits) you have on your machine and also a step by step test case scenario so we can try to reproduce and investigate the problem?
eshiva
Thanks Dan,
I do not have another VISTA machine. I am using VISTA 32bit OS and Advanced Installer 10.3 (Full version).
Can you please clarify me that is there any limitation of using in VISTA.
Shiva
Hello Shiva,
There is no limitation on Vista Operating System.
Can you please give us a step by step test case scenario so we can try to reproduce and investigate the problem?
eshiva
Hi Dan,
I tested on another VISTA machine and XP machine (Both are 32bit). Getting the same issue.
I have customized the background like re-sized the banner logo to full window (See attachments for Win7 & Vista).
In windows 7 & 8 i am getting full background image but in Vista & XP i am not. Please resolve this issue.
Shiva
Hi Shiva,
If you have enabled the Enhanced User Interface option from the "Theme" page, "Settings" tab please note that you need to run the .EXE and not the .MSI.
If this is not your case, can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
eshiva
I sent a mail to support@advancedinstaller.com (on 3rd) with my project file. No one is responded till now.
Shiva
Hi Shiva,
I'm not sure why you didn't get my last replay. I've tested once again your application but I cannot replicate the behavior. Had you tried to test on another clean machine and see if the behavior still persist?
Please keep in mind that some features require the "Enhanced User Interface" to be enabled. Also you can take a look on the Enhanced UI article for a better understanding of this feature.
Please note that the “Enhanced User Interface” option require the package as an .EXE (you can have an .EXE with resources inside or an .EXE with resources next to it).
So, can you please try to enable the "Enhanced User Interface" and see if the behavior still persist? In order to achieve that you can go in the “Settings” tab from the “Theme” page and select the "Always(install, uninstall and maintenance)" option. Also, you should go in the “Media” page and make sure that the “Package Type” is an .EXE.
