CaptainFapin
Radio button and install area help!
Problem one ) Image Image I have those folders ( and more to come) And i cant get the radio buttons to work. Ive read so many pages and tried so hard to get them to work or understand them. To no avail. If you were to set up those radio groups what would you put? maybe explain it to me so i can do it with future radio groups? and then later on i need a radio group to go to cetrain DLG's.
Problem two) Under files and folders i added the files im going to install. I was wondering how i can make it so instead of installing there it installs were the user wants. Reason i ask this is because even when in the DLG's the user picks a different area like desktop instead of program files, it still installs were i put them in program files.
Explain) Reason i ask the last one is because i made textures for games, and i need an auto installer because simply awesome! and keep in mind there will be many files with the same names.
And is it possible to add text in the DLG's the user can copy and paste? that way when asked for install area i can offer the main default install areas for x32 and x64?
easier to explain over skype? add me!
 TacoFest
and what would i need for a custom template?
And possibly explain in great detail how to make an auto updater. I found that one thread but i need people to keep in mind ill be using 000webhosting. and most threads, tuts, and webpages dont help
Re: Radio button and install area help!
In order to achieve this you can take a look on the How do I show a custom feature selection dialog article that may be helpful for you.
and then later on i need a radio group to go to certain DLG's.
In order to achieve this you can create the dialogs you want, then select the "Show only if..." option from their context menu and set a condition for each of them using the property related to the "Radio Button Group" control (i.e. RADIOBUTTONGROUP_1_PROP = "RadioButton_1").
In order to let the user choose where the files will be installed you should add your files in the "Application Folder" from the Files and Folders page, not in the "Program Files" folder.
To let the users copy and paste a text from a dialog you can add this text in "Edit Box" controls. To achieve this you can add an "Edit Box" control on a dialog, then copy its related property, go in the Install Parameters page, create a new property with the same name and in the "Value" field write the text you want to show to the user.
I'm afraid we cannot offer live technical support. Mainly this is because we have a lot of support tickets and each requires careful investigation. Because of our work load and limited resources, we cannot provide live technical support yet although we are planning to. This is why we tell our users our replies have a 24-hour approximate frequency (except the week-ends). Please keep this in mind in the future so you can organize, estimate and give your software's installer authoring the time it needs. This way there's won't be any time pressure before deadlines.
I'm afraid I don't fully understand what "custom template" do you refer to. Can you please give us more details (maybe exemplify)?
In order to create an update for your product you can take a look on our Using the Updater tutorial.
CaptainFapin
No that didnt help, all the links you gave me i have already seen. They make no sense at all. It says "set a condition" but not what you should put. Its not specific its of no help. I need someone to help me out here.
All the conditions should be set depending on your project configurations (features, radio button groups, etc). Can you tell us which conditions do you refer to and describe us a little more in detail which part do you need help with?
Also, for a better understanding, you can send us your .AIP (project file) to support at advancedinstaller dot com so we can investigate it.
