Brahnsuk
Customize Dialog - Change Text Color of Prerequisite Dialog
where I can change the color of the text from the prerequisite dialog?
Maybe in *.ini or *.aip file?
Thanks in advance
Current Version of AI: 16.5
Re: Customize Dialog - Change Text Color of Prerequisite Dia
In order to create a new text style or edit existing ones you can go in “aA Text Styles” tab from the “Theme” page.
Then you can go in the “Dialogs” page and set the attribute for the “Text Style” of the control property to the one you had previously defined.
If your prerequisites are “Feature-based” ones, unfortunately due to an Advanced Installer issue the text color for the “PrerequisitesDlg” is not set (it only remains black). A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention. Until then, unfortunately there is no workaround available.
If your prerequisites are “Pre-Install” ones, then I'm afraid we don't have support to edit the text style of the pre-install prerequisites wizard dialogs.
Brahnsuk
Hi Dan,
yes, our Prerequisite's are "Pre-install".
At the "Dialogs"-page I don't see something from the prerequisite-dialogs, so I thought I don't see the setting for it and asked.But now I know it, thanks
But now I know it, thank you.
You're welcome. If you have other questions, please let us know.
Return to “Feature Requests”
