wyzerd
Extract time excessive
Ok, the package is extremely large. and yes it is exceeding 20 minutes to complete the installation which is mostly a file drop. However, this message box is enough for the average user to abort the installation;
Another problem I have with compression is the extract path defaulting to [AppDataFolder]. [AppDataFolder] is accessible to the Current User only. The correct path should be [CommonAppDataFolder] which would be the same for all users and allow for Repair/Upgrade/Patch sequences for any administrator not just the one that did the original installation.
I used LZMA compression on this installation. I am going to try again with CABs instead. But I need to get the 7GB of files down to 4.2 so uncompressed isn't going to work, and I really don't want to make a multi-disk release of this.
wyzerd
Re: Extract time excessive
Whoops, I though tthis was fixed once before. I guess it wasn't;
http://www.advancedinstaller.com/forums ... =2&t=23020
As you already noticed this is our default setting. However, you can change accordingly the extraction path in "Media page -> Configuration tab -> Extract Location" field.
viewtopic.php?f=2&t=23020
Unfortunately, as it is mentioned in the above linked thread, this is a Windows Installer behavior. We'll try to add an improvement regarding this in a future version of Advanced Installer, but for the moment there are no immediate plans. Also, I cannot give you an ETA for now. Thank you for your understanding.
