R.Mueller
Tempory Files does not exists during a Major Upgrade
It seems, that all files, I added as "Temporary Files" are not exists during installation of a major upgrade. Hence I run some CAs, which needs those files, how can I make sure, they also exists during major upgrades?
Roland
Re: Tempory Files does not exists during a Major Upgrade
Hi Roland,
You can take a look on the Installer uninstalling temporary files on upgrade thread which debates the same issue.
R.Mueller
Hi Eusebiu,
sorry, I have overseen the other thread. Sometimes its hard to find useful things with the search functions.
Using a version number as part of the path has indeed solved the issue. Thanks!
Roland
