digitalrinaldo
Unable to find the Finish button
I am trying to attach an event to the Finish Button. I want to execute a custom action. I cannot seem to find the Finish dialog. I believe I am using the exe bootstrap installer. How do I exdecute a custom action when the application is installed?
Can I do it without user input? Can I listen to some event that indicates that the application has been installed.
Why does the UI for the Exit Dialog not match my Finish dialog. I have a test print button but I don't have the two checkboxes above in my application. I added the test print by applying it to all dialogs. I never found the dialog that was the same and I also don't understand why the button is "back" instead of finish.
Dialog doesn't match what I see on the screen
Re: Unable to find the Finish button
It seems that the bitmap image available on that dialog is moved down, so it covers the "Finish" and the "Cancel" buttons and they are not shown during the installation. To fix this you can select the image (i.e. click on the blue image from the left) and drag it up until the buttons are displayed.
Let us know if this helped.
digitalrinaldo
I fell stupid -- Thank you.
Is there another way to call a custom action without using a button. For example
If the application is successfully installed and the application exits. I would like to call a custom action.
If you want to execute a custom action without using a button or another control, you can add it with sequence in the Custom Actions page.
