ucr
Custom Quick Selection Tree
Is it possible to customize a Quick Selection Tree?
My problem is this:
I have 4 main features, that aren´t really features but act like a group.
Under each one i have the "real" features,
But only 2 of those main features have features i want people to choose to install or not.
The other 2 i have, i want them to choose only one of them.
I accomplished this by making 2 "checklist" for the first two, and "Radio Button Groups" for the other 2
I would like to choose the first 2 "main features groups" to be displayed on the "quick selection tree" and not display the other 2
It works just fine, but i would like to have a text field describing the option selected on the "checklist", but i only found in the "subscribed events" a "describe description for the selected tree item".
I cannot find some way to display the selected feature on a "checklist" and as i have two of them in one dialog, i would have to have 2 description text boxes.
Re: Custom Quick Selection Tree
In order to achieve that you can go in the “Organization” page and in the feature property you can select the “Not Displayed” option for the “Feature Tree”.
In order to achieve that you can have Control Conditions that are associated with the related text.
I've attached a .zip file which contain a sample project which implement a similar scenario. Also you can take a look on the Disable “Next” until radio button is chosen thread which debates a similar issue.
Please let us know if that helped otherwise give us more details.
test.zip
(4.18 KiB) Downloaded 389 times
ucr
Thank you.
I just like to say that your support team is BY FAR the best one i have ever had the pleasure to contact.
All doubts i placed, were clearly explained and in record time.
Keep up the good work
If there is anything we can help with, please let us know.
