aldenlong
Install attempt brings up Windows installer dialogue
I am attempting an installation without full administrator rights. I don't know if that is relevant or not, but the behavior is odd. None of the installer dialogues appear, and no log file is generated. Instead, a message box listing windows installer command line options appears [attached]. I have also attached my project file. I would appreciate any help you can give me.
E220-E500 Demo Software v15.00.20.aip
Project file
(61.91 KiB) Downloaded 510 times
Screen capture of message box
Demo installer error.png (44.06 KiB) Viewed 4843 times
Re: Install attempt brings up Windows installer dialogue
This happens because a command line in your project is not correct. In your .AIP I saw that in the Media page you written the following command line in the "MSI Command Line" field (“/L*V %temp%\Install.log). The quotes from the beginning of the command line are not placed correctly. Can you please remove them and see if the behavior persists?
aldenlong
Doh! I even have a specific note about this in the procedural document I am writing. Didn't connect. Thanks!!!
