drivard
Display issues with ℠ character
I'm using AI 8.4 for our installers. One of our customers requires that the ℠ character appear in the product name and folder groups.
"MyProduct℠ Foobar" for example.
There are two main problems that I am having with this currently.
One is that AI shows the ℠ properly all over the UI, including the dialog editor.
However, the generated installers do not properly show it, they show a ?.
I've attached a screen cap showing the dialog editor on the left, and the running app on the right.
The second problem is the ? causes an error with illegal folder names.
I will separately mail the project file to the support email address so you can confirm things.
What to do? This is becoming a big problem for our customer and our internal management.
Any thoughts?
I've tried using encoding, not encoding, and no luck thus far.
Dialog Editor on the left, and running app on the right.
unicode display issue.png (111.82 KiB) Viewed 4687 times
Re: Display issues with ℠ character
This may happen if the related character is not supported by the code page of your installation package. However, in order to achieve what you want can you please enable the "UTF-8 codepage" option, from "Media page -> MSI tab -> Database Code Page", and see if the behavior still persist?
drivard
It worked!
I never noticed that check box before.
Thank you so much! This will really make some people around here very happy!
:D
You're welcome.
