R.Mueller
Problems with Prerequisites after updating to AI 10.5
Hi Advanced Installer Team,
after updating my setup projects to AI 10.5, the "Supported Windows Versions" install conditions for prerequisites got screwed up completely. I have received some reports from our testers, that setup now tries to install x64 prerequisites on a x86 system. I checked that and found out, that all OS conditions are set somehow. Especially 32-bit-only prereqs are set to install on all 64-bit windows versions, but also other 32-bit OS conditions have changed.
Sure I can fix all the conditions manually, but from my point of view, AI should not touch the existing conditions, when the supported OSes are changed.
Is this an expected behavior (maybe due to Win 8.1 or removal of Win9x support)?
If yes: Which parts of setup should be reviewed for any unexpected or unwanted changes due to the update to AI 10.5?
Roland
Re: Problems with Prerequisites after updating to AI 10.5
Hello Roland,
Indeed, this is an Advanced Installer 10.5 issue. We are aware about it and already implemented a fix in the next version of Advanced Installer (10.5.1) which should be out in a couple of days. Until then, you should build your project files using version 10.3 (or lower) of Advanced Installer. Also, after version 10.5.1 of Advanced Installer will be released you should migrate your project files directly from version 10.3 (or lower) of AI to AI 10.5.1.
R.Mueller
Hi Daniel,
I understand this as a general recommendation not to use AI 10.5, is this your intention?
Roland
Hello Roland,
You can use the 10.5 version of AI to create new projects, but you should not migrate your existing projects created with older AI versions (10.3 or lower) to AI 10.5. You should migrate your existing projects directly to AI 10.5.1 after it will be released.
R.Mueller
Hi Dan,
when is AI 10.5.1 scheduled?
Roland
Hello Roland,
The 10.5.1 version of Advanced Installer is scheduled to be released today. So, it should be out today or at the latest tomorrow.
Hello Roland,
This was fixed in version 10.5.1 of Advanced Installer released on September 06, 2013.
R.Mueller
Hi Daniel,
the Prerequisites issue seems to be fixed now, at least partly. After converting the project again from 10.3 level to 10.5.1, I run through the Launch Conditions to check Windows 8.1 support and got this error message:
AI crashed afterwards without further message. I restarted AI and checked the Launch Conditions again, and added Win 8.1 Support - this time without crash.
Any ideas why this happens?
Roland
R.Mueller
Hi Daniel,
the issue is reproduceable. If you at the Launch Condition panel and the project contains several build types and you switch between them to add Windows 8.1 Launch Condition - then it will crash, when you restart AI between the changes, it works.
Roland
Hello Roland,
I've tested your scenario, but I cannot reproduce the behavior. Can you please give us a more detailed step by step test case scenario? Also, it would be useful if you can isolate the behavior in a sample which reproduces the behavior so we can investigate it.
Hello Roland,
We have further investigated this and we were able to reproduce the behavior. A fix for this issue will be implemented in a future version of Advanced Installer, thank you for bringing this to our attention. Until then, as a workaround you can try the following steps:
- open in AI 10.5.1 the project created with AI 10.3
- using "Save as" option save the project under a different location or under a different name
- open the new saved project in AI 10.5.1
Let us know if this helps.
R.Mueller
Hi Daniel,
I wanted to send you my development project right now, I where just bound today in too many meetings. I am glad, that you were able to reproduce the issue.
As mentioned in this thread above, the problem on my side was also being solved with a save after update and restart of AI, then it works.
Roland
Hello, Roland
This was fixed in version 10.5.2 of Advanced Installer released on September 13, 2013.
