argaz
useAppPoolCredentials IIS setting
The web application that we're installing is working in a load balanced environment with windows authentication, which means that we have to have the useAppPoolCredentials setting set to true for the authentication to work (as been documented here: http://blogs.technet.com/b/askds/archiv ... ncing.aspx).
Unfortunately, when the web site is being installed, that specific attribute is being explicitly overriden and set to useAppPoolCredentials="false" at the web site's location section. Currently we have a workaround of a custom action running IIS' appcmd in order to edit the applicationHost.config after the installation.
Is there a way of setting this attribute to true natively, or preventing it from being overriden?
Our environment is Advanced Installer 10.0, IIS 7.5, Windows Server 2008 R2.
Thanks.
Re: useAppPoolCredentials IIS setting
Sorry for the delayed reply. This seems to be an Advanced Installer issue, but a fix will be available in a future version of Advanced Installer, thank you for bringing it in our attention.
As a workaround, if in the "Authentication" tab of your web site, the "Allow anonymous web access" is disabled, you can enable it, choose the "Use application pool identity" option and then disable it again as you can see in the attached image, otherwise you can use your custom action until we will fix it.
Just let us know if you have any other question.
Application Pool Authentication.png (51.55 KiB) Viewed 6891 times
argaz
Thanks for the reply, so basically this will be fixed somehow in a future version? Will it appear in the release notes?
Indeed, it will be fixed in a future version of Advanced Installer and we try to do it as soon as possible, it will also appear in the release notes. Also, we will notify you on this thread when the fix will be available. Thank you for understanding.
This was fixed in version 10.7 of Advanced Installer released on November 11, 2013.
