shetty_rohan
Problem with the AdvancedInstaller 10.5
I have written a setup which used to work fine in the AdavacedInstaller older versions. But after upgrading it to the latest 10.5, I am unable to open the .aip file
When I open the aip file, I get the following error
Can you please help with this??
Rohan
setup-windows-386.aip
aip file
(104.47 KiB) Downloaded 461 times
Re: Problem with the AdvancedInstaller 10.5
Hi Rohan,
Thanks for the file, we'll check this out and provide a fix ASAP.
Hi Rohan,
We found that in the Table Editor page, "LaunchCondition" table, the "Description" for the second condition is changed (probably by you), when the "RESELLER_BUILD" is selected on the toolbar. It seems that in this case Advanced Installer has an issue to convert the launch condition, but we have already started to work on fixing this.
As a workaround, you can revert to the original description, save the .AIP in AI 10.3, then open it in AI 10.5 and modify the description again as you need it.
Let us know if this helped.
shetty_rohan
thanks, it worked
In the meantime we discovered another problem in your project, caused by a older version of Advanced Installer. This can be fixed only manually by us.
I attached the fixed aip file. This you must open directly with Advanced Installer 10.5.1, that we will release in the next hours. After you have saved the project with 10.5.1 you can re-apply the changes from Table Editor,
as you had them before upgrading from 10.3.
The project you converted to 10.5, using our workaround, should not be used anymore, you can delete it.
Thank you for sharing with us your project, it helped us improve considerably the tests sets we execute when converting the projects.
setup-windows-386 -FIXED.aip
(100.83 KiB) Downloaded 584 times
shetty_rohan
Hi Bogdan,
Thank you for your help, and appreciate the fixed code.
However, I have done couple of minor changes in my older project. Can you please do you fixes in the attached code.
Rohan
Original file
(100.86 KiB) Downloaded 488 times
Hi Rohan,
I am very sorry but I cannot fix the attached project because the launch conditions were already converted. Not even us cannot fix them manually as the launch conditions conversion complexity is huge.
This is the reason why I fixed the older version of the aip file.
Please apply the changes you did starting from the fix project I sent you, it is much safer than me trying to decompose the entire launch conditions and manually recreate them.
P.S. If you are not in an hurry please wait for 2 more days, as we will release version 10.6 which also includes a small fix for launch conditions, I am not sure if it applies for your project or not, but it is better to be safe.
shetty_rohan
Hi Bogdan,
No problems. I will wait for your next fix. Do let me know once this is taken care of( worst case, I could undo and use your aip file)
Rohan
Hello Rohan,
The 10.6 version of Advanced Installer was released on September 30, 2013.
shetty_rohan
Thanks. I have built using this, and it seems to be working fine. Do let me know if you need the setup file for any analysis.
