m4rcel
Big issue witch Polisch special charakter
See screens.
This problem first happened on version 10.1, i report it to support@advancedinstaller.com (Bogdan) 06-05-2013. He reply:
Thank you for bringing this to our attention. We'll have a fix for it ASAP.
Then You release 10.2 Unfortunately error which I reported not been repaired, next 10.3 the same. In this time our Maintenance plan has been expired. I e-mail to you 31-07-2013 and 03-09-2013 you don't reply. What can we do with this?
Re: Big issue witch Polisch special charakter
Please keep in mind that the "Display error message" custom action is an Windows Installer custom action and it seems that it has a limitation regarding UNICODE characters.
However, you can use the "Display message box" custom action which is an Advanced Installer custom action and it supports UNICODE characters only if you go in the Media page and select the "UTF-8 codepage(support Unicode characters to be displayed)" option from the "Database" group.
Let us know if you have any other question.
