er.anuj21
xml file option is disabled in advanced installer
Hi , i'm using trial version of advanced installer 10.5.1. I have to edit a xml file i.e standalone.xl that consist of a port number .But i could not click on xml file option at top side of the installer screen . Though i have licence key of Advanced installer but i have activated it another system and today using an advanced installer trial version.
How to enable the xml file option ?
Paint file
Paint file
mihai.petcu
Re: xml file option is disabled in advanced installer
That file is added as a regular file only. To edit it at install time using the XML Editor you need to add the same XML file in the Windows Installer format as well. Read more in the XML Files Page article.
er.anuj21
Thanx for replying mahai . But can you please elaborate what you replied because i'm not fully getting it . I need my standalone.xml file to be edited . I have to change the port number that exit in standalone.xml.
My requirement is :-
double click on the standalone.xml file and then edit the XML element attribute which contain the port number value like this:
Value: [PORT_PROP]
er.anuj21
Mikai thanx... i got the answer . :)
