guidogast
Installer Overview screen
I've been looking around the forums, but I couldn't find anything regarding this matter...
If you choose for a custom install and you can choose between specific features... Is it possible to get a screen with an overview of what you chose in that feature list, right before you press the install button?
Basically is it possible to have a list like this: http://download.scope4mation.nl/e91fa32 ... er-Ove.png
As you can see, the list can vary from small to big and displays information that the user had to fill in before this screen.
I hope this is clear and that someone can help me out with this.
Sincerely,
Guido
Re: Installer Overview screen
Hello Guido,
In order to achieve what you want you can edit the "Description" field of your features from "Organization" page. Also, you can use installer properties (in the "Description" field) associated with UI controls which will be edited by the user during installation. Also, you can try to create a custom feature selection dialog.
A similar issue is also debated in our "Update Static Text" thread.
