jarlath
Creating A CD/DVD installation
I just purchased the PRO version of Advanced Installer. Up until this time, I have been using the Install Shield lite version that comes with Visual Studio. In Install Shield lite, I was always able to create a DVD version of the application including an ability to add autorun to it. However, I do not see any ability to do that in the PRO version of Advanced installer. As this is such a common thing on even freeware installation builder, I am sure I must be missing something. If anyone can assist, I would appreciate it. Thanks much!
Re: Creating A CD/DVD installation
Hi and welcome on our forums,
Thank you for registering Advanced Installer.
The support for CD\DVD autorun from Advanced Installer is a little bit more complicated, it involves included our own executable
and many more customizable options. This requires an Enterprise license to use it.
However, you can still get the setup package created with the Professional edition and manually create an autorun.inf file,
using Microsoft documentation.
I included a sample file from where you can start. This file you can place on the DVD root, next to the ico and setup file mentioned in it.
You can also use relative paths if you want all the resources in a separate folder next to the file.
Autorun.zip
(227 Bytes) Downloaded 687 times
jarlath
Thank you...Thank worked great!
matt123
I have just spent nearly half an hour trying to find the autorun option, to no avail - so two observations:
1. Autorun really should be available in the PRO version at least - its a fairly basic requirement, leaving it out feels a bit "cheap" to me.
2. *Please* add some sort of note at the top of manual pages that indicate the version in which certain features are available. I ultimately found this forum post after giving up on the documentation and Googling - no where that I read in the manual did it state "Enterprise only", so I was left confused and looking through all the available options. This would have saved me half an hour at least!
thanks,
Matt
Hi Matt,
As I stated in my first post, you can include your own autorun.inf file as Microsoft documented for any package built with Advanced Installer, even those create with the free edition. The sample I attached should make this task pretty easy.
We have a full list of features, split by the license type required for each of them on our web site.
Also, the simplest method to find a major feature is to use the search "Quick filter", available on the top of our left menu. If you type in there "autorun" for example you will automatically see the page. When trying to select the page Advanced Installer will prompt you telling this page requires at least an Enterprise project.
Currently we specify if a certain feature requires a specific license only in our tutorials. This is because our current paradigm is of showing in the left menu only the pages/features accessible to your current project type, therefore anything is missing requires a higher project type. Only the search can show this page in its results, exactly with the purpose of revealing new features that our users might look for.
Advanced Installer 10.9000.png (6.45 KiB) Viewed 8233 times
ehardin
I have Enterprise Version 8.2 In one of my projects CD/DVD Autorun is available but in the new project that I am trying to create it is not available as in not even shown. How do I get it to show up as a selection?
Ed
Hello Ed,
This may happen if you have created a project of a lower type than "Enterprise". Please note that the "CD/DVD Autorun" feature is available only starting with the "Enterprise" edition of Advanced Installer. To upgrade your current project type you can go, in AI 8.2, to "Project" menu option -> "Options..." -> "Project Type" tab.
