jackfundter
Installer keeps resuming the setup
For testing purposes i have aborted the installer during the install now the installer keeps trying to resume the instal while i want it to start over again.
I tried to restart my pc and tried to find a register value in HKCU\.......\run but it isnt there.
How can i fix this?
Greeting,
Jack
Maverick
Re: Installer keeps resuming the setup
Hi , I have the same problem after installing 10.5.1. Setup has installed my Software and after reboot Setup is starting again.
Regards
Gary
I'm not sure why this happens. Can you please send us your .AIPs (project files) to support at advancedinstaller dot com so we can investigate them?
