Shania
Error text styles
Hello! Help me, please.
If the "Reboot Behavior" set "Force Reboot after install", then a window appears asking you to reboot. Text style by default does not apply to this window (User Interface - Themes - Text Styles - Set Default). The current encoding is not supported by some machines. Where to set up this window, its character set?
P.S. 1. Similarly, when you uninstall program.
2. Create a multilingual package.
Thank you.
Error text styles.jpg (37.52 KiB) Viewed 8764 times
Re: Error text styles
I'm not sure why you encounter this behavior. Can you please tell us the version of Advanced Installer that built the package, the Operating System's version and language of the machine that encounter the problem and also a step by step test case scenario so we can try to reproduce and investigate the problem?
Shania
Hello!
When I create a new package with the same set of languages, the error is not repeated. But I need to correct an error in old package. :(
Encoding is broken in the windows, which I don't see in the "User Interface - Dialogs". Where to watch the window system?
Thank you.
These dialogs are from Windows Installer, displayed when the package runs with Basic UI and they are not available for customization in the Dialogs page.
Can you please send us the two .AIPs (the old one and the new one) to support at advancedinstaller dot com so we can investigate them and try to find the problem? Or can you describe us the steps that we can follow to reproduce the behavior?
Shania
Hello!
I removed all of the old .AIP-file. The error remains. When the delete program, the text is not correct.
Thank you.
Shania v.1.0.0.aip
old .AIP-file
(22.79 KiB) Downloaded 579 times
First of all I apologize for the delayed reply.
I tested the .AIP file that you attached to the previous post, but everything worked well to me. Can you please tell me which is the language of the machine where it does not behave correctly?
Shania
Hello, Eusebiu!
I created a new project and moved all of the data from the old project. Although I'm interesting how to change the text in the uninstall window.
Thank you.
the uninstall window.jpg (16.24 KiB) Viewed 8705 times
In order to achieve this you can go in the Table Editor page, "Error" table and modify the message for the "20" and "21" rows.
Shania
Thank you very much!
Can I edit the font, size, and encoding of these messages?
I'm afraid that these are Windows Installer messages and their text style cannot be modified.
