DimasSup
Often, button and icon will appear only if move form outside
Hi, we have a problem with installer. Often, button and icon will appear only if move form outside desktop boundaries (forces windows to refresh content).
We have the latest version of Advanced Installer.
Software: OS: Windows 8.1; IE: version 11.0.9431.195
Also, we have attached а screenshots:
Screenshot 2
Screenshot 2
Image 2.png (711.02 KiB) Viewed 4424 times
Screenshot 1
Screenshot 1
Image 1.png (601.16 KiB) Viewed 4424 times
Re: Often, button and icon will appear only if move form out
I'm not sure why you encountered this behavior. Can you please test your installation package on other clean machines and see if the behavior still persist? Also, please make sure that you have enabled the
Enhanced User Interface option from the “Settings” tab in the “Theme” page.
Please note that the “Enhanced User Interface” option require the package as an .EXE (you can have an .EXE with resources inside or an .EXE with resources next to it), so you should go in the “Media” page and make sure that the “Package Type” is an .EXE.
DimasSup
Same behavior happens on some user's comps.
Also, we have checked: Media -> Configuration -> Package Type is Single EXE setup(resources inside).
Can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
