er.anuj21
MIGRATION OF MY ARCHITECT VERSION APPLICATION TO JAVA APP
Hi team ,
When i started using advanced installer trial version then i have created my applcation using architect version but after then i have pusrchased the license key for java application. Even i have registered the licence key. But when i'm importing my app in java Project type and giving build then trail version of architect comes up.
If i'm creatting a new application using java Project type then build is happening correctly. Is there any way that i can migrate my architect Projrct type to java Project type ?
Screenshot attached.
Re: MIGRATION OF MY ARCHITECT VERSION APPLICATION TO JAVA AP
Hello Anuj,
Unfortunately you cannot downgrade the project type. If your project has a higher project type (Enterprise or Architect), then in order to be able to build it using your license key you should create the project from scratch as a Java project type.
