er.anuj21
How to change the Install button to Next button
Hi team,
I have a screen of FolderDlg where i could see a Next button . But when i give build and execute me .exe file then instead of getting Next button i see an Install button. Though i will have a install button in the very next screen of of FolderDlg . Could not rectify this . So please reply.
Screen shot attached
Re: How to change the Install button to Next button
Please keep in mind that using other theme then the “Classic” one, automatically is enabled the “Enhanced User Interface” option in the “Settings” tab from the “Theme” page.
You can take a look on the Enhanced UI article for a better understanding of this feature.
Please note that the “Enhanced User Interface” option require the package as an .EXE (you can have an .EXE with resources inside or an .EXE with resources next to it).
So, in order to your application work properly you should have the “Enhanced UI” enabled. In order to achieve that you can go in the “Settings” tab from the “Theme” page and enable it.
Also, you should go in the “Media” page and make sure that the “Package Type” is an .EXE.
Please let us know if that helped, otherwise give us more details.
er.anuj21
I have tried it what you suggested but not working. Still i'm getting a Install button after i execute it. Though before build i can see Next button into it.Attached screen shot for Theme setting page.
And in Media , Package type is Single EXE setup (resources inside)
What else Info you need please do ask me . :)
er.anuj21
yes ... tried it and its working well now . thanx team
