er.anuj21
Could not acces to your network eror
Hi team ,
I wanted to add a new feature i.e browse to folder to my .exe file . I just followed the the link http://www.advancedinstaller.com/user-g ... older.html
and completed all the steps .Given a build and double clicked the .exe file. But during the execution at the very first screen of exe file , i got an unwanted error . Screenshot is attached. Kindly response asap.
Thanx
Re: Could not acces to your network eror
This may happens if you haven't defined your property with a right value. So, can you please go in the “Install parameters” page and make sure that the property you had defined is initialized with an appropriate value(e.g. C:\).
Please take a look on the create property article which may be useful to you.
er.anuj21
The link that i have attached in this post i.e http://www.advancedinstaller.com/user-g ... older.html has a sample project of Browse For Folder. I followed exactly all steps. There i havn't seen any property value mentioned and just only property name as MY_DIR at the Install Parameters.
I just gave property Name as MY_DIR and property Value as Your Value. One thing more i have also defined one more property over there ofname [PORT_PROP] and value 8080.
Can you please take a closer look on the step 3 from the Browse for a folder article:
3. In the Custom Actions page, create a "Set installer property" custom action with sequence before the "Wizard Dialogs Stage -> Searches" action group. Use the following options for this custom action:
a) Property: MY_DIR (defined in the "InstallParameters" page)
b) Value: [WindowsVolume]
Please make sure that you have executed correctly this step.
If the behavior persist, can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
