er.anuj21
How to launch a batch file at target machine
Hi ,
Need urgent help .
I need to run a batch file i.e test.bat .
Till now what i was doing is that i have defined a test.bat file in custom action named Launch File.But in the working directory i have hard coded the path i.e C:\Program Files (x86)\Latilla\C4i .But now i want to browse folder and locate them into the desired location in the system i.e C:\Users\lordpintai\Documents\mytesting\ .
test.bat file is added to Files and Folder. Now i want to run test.file after the copying of all the files to the desired location. i.e C:\Users\lordpintai\Documents\mytesting\ . Here copying of all the files means after following of all the steps of execution of .exe file , all files attached to Files and Folder are copied to my desired location i.e C:\Users\lordpintai\Documents\mytesting\ and launch the test.bat file.
Re: How to run a batch file with the browsing location
Please note that the APPDIR is the public property that contains the path for the installation folder.
Please take a look on our Properties article which may be useful to you. Please keep in mind that this property is referenced by formatted data type so it is resolved at runtime.
In order to launch a batch file, you can go in the Custom Actions page and add the predefined Launch file custom action with sequence.
In the custom action properties, in the File to Launch line just select your batch file. (e.g. [#MyFile.bat]). Also, if you want to launch a BAT file with parameters you can use a similar approach like in our pass parameter to batch file thread.
Please let us know if that helped, otherwise give us more details about your specific scenario.
er.anuj21
Thanx for answering
For more clearance , i've updated the question.
.I'm still struggling with it . I tried 2 approches what you suggested me :-
Approach 1)
"[#test.bat]" "[APPDIR]" in Command line of Launch File Properties and given a build and then executed my .exe file but still test.bat didn't launched.
Approach 2)
[#test.bat] in the File to Launch option of Properties. Still didn't launched.
My test.bat file is added in the Files and Folder option of Advanced Installer.
er.anuj21
Re: How to launch a batch file at target machine
In my Install Parameters , I have defined Application Folder : [ProgramFilesFolder][Manufauturer]\[ProductName].Is it because of it ?
I'm not able to rectify it :cry:
er.anuj21
yahoooooooooooooo ... problem rectified :)
:D
I'm glad you got this working. If you have other questions, please let us know.
iansel4
How did you launch the batch file?
Can you please give us more details about what do you want to achieve for a better understanding of your scenario?
Also, in order to see how to run a .bat within a setup created with AI, you can have a look on our "Launch a CMD or BAT file" article.
