tomas.maruska
Cannot invoke custom action during rollback
I have custom action, which executes some DB scripts (number 1 on screenshot). And I want to rollback it in case something goes wrong. So, I made another custom action which should return DB to original state (num 2 on screenshot).
For test purposes, I returned 'Failed' from last custom action in sequence (num 3 on screenshot) and I added MessageBox.Show(...) into custom actions #1, #2 and #3.
When installing I get MessageBox for #1, then #3. After action #3 setup starts rollback, which is absolutelly correct. But, then rollback ends without invoking my custom action...
Can you tell me what am I doing wrong?
I'm using Advanced Installer v10.5.2. Find attached screenshot and logs from setup described above.
log.zip
(66.9 KiB) Downloaded 271 times
Re: Cannot invoke custom action during rollback
Please keep in mind that a "rollback" custom action is always executed when the system is being modified (deferred), hence if your #1 and #3 custom actions are executed "immediately", the #2 (rollback) custom action is not reached when the #3 custom action throws an error code and that is why it is not executed.
So, in order to achieve what you want you can set the #1 and #3 custom actions to be also executed when the system is being modified (deferred), or you can just drag and drop the #2 custom action above the "Remove Resources" action group in which case it will always be executed during rollback.
tomas.maruska
Thank you, I moved rollback action above "Remove Resources" and it was invoked.
