crandom
Error when opening a project
I'm getting the following when opening a project:
[SEH_AV_READ_BADPTR] ACCESS_VIOLATION (0xc0000005) at address [0x00eb6723]
Advanced Installer 10.6 build 53162
*** Stack Trace (x86) ***
[0x00eb6723] -----
[0x08408ee4] -----
[0x0080854c] -----
[0x778ae3a0] RtlAllocateHeap()
[0x6d000269] malloc()
[0x6d00233b] operator new()
Rolling back the version of AI allows us to open the project. Rolling back the project (i.e. to a previous commit) doesn't.
crandom
Re: Error when opening a project
The AIP project has been emailed to your support address.
Hello Cain,
Indeed, this is an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention. It seems this happens due to a corner case of an Advanced Installer bug regarding launch condition conversion from 10.3 to 10.5. Please keep in mind that starting with version 10.5 of Advanced Installer the support for Windows 9x, ME and NT target platforms was removed. Starting with Advanced Installer 10.5 you can create packages only for Microsoft Windows 2000 and higher operating systems.
In order to avoid this issue you can proceed like this:
- open your project in Advanced Installer 10.3 version
- go to "Launch Conditions page -> System tab" and check all OSs from "64-bit Windows Versions" and "32-bit Windows Versions"
- save you project
- open your project in Advanced Installer 10.6, go to "Launch Conditions" page and configure again your supported operating systems
This was fixed in version 10.7 of Advanced Installer released on November 11, 2013.
