ElleNearMello
How to include LabVIEW runtime?
I am evaluating Advanced Installer.
My company uses National Instrument LabVIEW 2013 to make software.
This language/enviroinment is able to produce exe files, but they need a proper runtime to be executed.
LabVIEW is also able to create installers with exe+runtime embedded, but it has so few options, and it is very limited compared to Advanced Installer (it cannot translate the dialogs, cannot modify dialogs, add services, update, etc...)
The runtime is this: http://joule.ni.com/nidu/cds/view/p/id/4059/lang/en
That exe is quite big (252MB), but it is an auto-extracting zip, and it has a main setup.exe (1)
Content of the runtime (1)
and it will call additional sub-installers (2), sometimes causing a machine reboot request.
Content of the runtime (2)
So my question is:
Can Advanced Installer create an installer (exe or msi) that incorporate this LabVIEW runtime?
How to do this? Should I use add pre-requisite and call the setup.exe at the end as a custom action??
The runtime is NOT available as a merge module I think.
I would like to first install my software into a folder, then call the runtime setup.exe at the end.
I am not able to make it works.
Re: How to include LabVIEW runtime?
In order to achieve that you can use the related software as a prerequisite. For that you can go in the Prerequisites page and use the [New Package Prerequisite] toolbar button to create a new prerequisite using files from disk or you can use the [New URL Prerequisite] toolbar button if you are using a prerequisite from an online location.
Please note that you can change when a prerequisite is executed by dragging it over the appropriate folder (Pre-install, Feature-based or Post-install).
Please take a look on the Add prerequisite article which may be useful to you.
If you need any help, please let us know.
