we use advanced installer to deploy our java program (jar).
When starting the jar file the program expects a command line parameter (like --imagepath=test.png).
As i figured out, the generated exe wrapper passes given arguments automatically to the jvm when starting the jar.
A call to wrapper.exe --imagepath=test.png does work and the java programm receives the imagepath parameter as argument.
But i am not able to use any whitespaces in the path.
I tried the following possibilities but non of them work:
- wrapper.exe --imagepath="c:\path with spaces\test.png" -> results in "c:\path as parameter
- wrapper.exe --imagepath='c:\path with spaces\test.png' -> results in 'c:\path as parameter
- wrapper.exe --imagepath=c:\path with spaces\test.png -> results in c:\path as parameter
Can you please give me some advice how to pass parameters with space with the exe wrapper to my program?
Thank you in advance
Sebastian
