Brahnsuk
Overwrite File which is "permanent" and "never overwrite"
for some components we set the attributes "permanent" and "never overwrite" because we want to keep the these files by an update/upgrade (e.g. v1.0.0 => v1.0.1)
Now for our new main version (eg. v1.0.1 => v2.0.0) we have to overwrite some of these files (which also maybe changed from the user).
I've read about the "File Operation" tab (http://www.advancedinstaller.com/user-g ... s-tab.html) "Overwrite only if the existing file is older". That looks good for our problem, but I don't can see this tab.
So,...
1. Are there any conditions where the tab is invisible? (we use the v8.9 of AI)
2. Today (the installations by our customers) don't have file version-number of the files. I would set the file version to "User specific" = 2.0. Is it possible that AI will overwrite it although the attirbutes are set to permanent and never overwrite?
summarized:
some files should be overwrite if the main version is higher, but not within the same main version... Can someone please help me? If this is not possible with AI settings maybe with a *.vbs or something??
thanks in advance!
Current Version of AI: 16.5
Re: Overwrite File which is "permanent" and "never overwrite
No, the "File Operations" tab is not invisible. It was added later in Advanced Installer and it is available starting with version 9.4.
I'm afraid that Advanced Installer will not overwrite a file if the "Never Overwrite" attribute is set for it.
summarized:
In order to achieve this you can follow the steps below (for this scenario you need at least Advanced Installer 9.4):
- go in the Upgrades page, use the [New Upgrade] button and create an upgrade rule like in the attached image
- go in the "File Operations" tab of the files that you don't want to keep, select the "Do not overwrite existing file (Preserve file content)" option and use the condition: NOT UPGRADE_FILES
- every (only) time the main version of your package is increased (e.g. v1.0.1 => v2.0.0), the "Max. Version" from the created upgrade rule should be also increased (e.g. 1.0 => 2.0)
- build and run the package
Upgrade Rule.png (53.81 KiB) Viewed 2994 times
