MikeH
Custom Action Execution Stage
I need to call a custom action in between the installer installing files and creating registry values. For example, I need my files to be installed into the installation folder, I will then call an executable within the installation folder and then I want the installer to create the registry values specified within the MSI. Is that possible?
I am thinking the process is
Standard Action: InstallFiles
Wait until completed
Custom Action: Call my executable
Standard Action: WriteRegistryValues
Mike
Re: Custom Action Execution Stage
Hello Mike and welcome to Advanced Installer forums,
In order to launch your .EXE file you can go in the Custom Actions page add the predefined Launch installed file custom action with sequence and select your .EXE.
You should choose the When the system is being modified (deferred) option from the Execution Time pane.
Also, select the custom action and use the [Move] button to schedule it after the InstallFiles standard action.
