I use AdvancedInstaller in our buildserver to create an msi on every commit to the repository. I use the command line api for this (/build foo.aip). Unfortunately, this creates a setup that always has the same version number. I want the setup to have the version major.minor.svn-revision. So I added a few lines to the build server that alters the aip file before building:
- Set <ROW Property="ProductVersion"> to the intended version
- Set <ROW Property="ProductCode"> to "1031:newguid 1033:anothernewguid" to make this a major upgrade
Is this a valid approach? What am I doing wrong?
Thanks in advance,
Alexander
