RobsonShelterit
Doubts organization.
Hello!
One more doubt many. : D
'm Finding difuldade in a process at the facility in Organization have three installation features, where one must be installed in accordance with the condition "TXT_DESK = YES" as shown in image below. When I perform the installation, not the expected behavior occurs. TXT_DESK may vary from YES to NO, when OWNED is YES, it usually installs the feature, and when the condition is equal to NO, it should ignore the feature installation.
The problem that occurs is that the option is qnd to YES, it does not install anything. I've tried several ways, but all attempts were invalid.
How to proceed in this case, I'm doing the correct procedure?
I'm waiting for a return!
Regards, Robson.
RobsonShelterit
Re: Doubts organization.
I'm trying to use the following script!
Function Teste()
Dim iRequestState
iRequestState = Session.FeatureRequestState("EASAPLICACAO")
Session.Property("TXT_UM") = iRequestState
End Function
But the return is not expected. Am I doing something wrong?
See the error shown in the attached image.
Hello Robson,
If you want to install a feature based on user selection during Wizard Dialog Stage then you can use a similar approach like it is described in our "Show a custom feature selection dialog" how to.
Function Teste()
Dim iRequestState
End Function
Please take a look on our "I can not use Session.FeatureRequestState in inlinescript" thread which could be useful for you.
If you still encounter problems implementing your scenario please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them? Also, please give us a more details about what you are trying to achieve.
RobsonShelterit
Hello !
Trying to explain my situation.
I have a customization dialog where it hesitate three installation options of my tool :
Application option
Script option
Prerequisite option
PREREQUISITE : is SQL Server Express 2008 R2 ;
SCRIPT : is a SQL script that will be executed ;
APPLICATION : is my application itself , dll 's and executable system .
I need it to behave as follows:
- When I did not request the installation SCRIPT , my PREREQUISITE should not be installed .
- When selected the SCRIPT one TestODBCConnection will be done to check if the instance is specific to my application already existing or not ( SQLConnectionOK ) . If the instance exists, the prerequisite should not be installed if the instance does not exist, the prerequisite must be installed .
I am creating these options for the customer to create the database on a server if it needs it, and applying it to another location . Or if you prefer to install it all ( local) .
How to proceed in this case?
I've tried a solution in all forums Advanced internal , but without success .
Thank you in advance for help!
Robson Sisnande .
Hello Robson,
In order to implement this scenario you can proceed like this:
- go to "Dialogs" page and on your customization dialog add three check box controls like this:
  • Text: Prerequisite
    Value: checked
    Property Name: PREQ
    Text: SQL Script
    Value: checked
    Property Name: SCRIPT
    Text: Application
    Value: checked
    Property Name: APP
- go to "Prerequisites" page and add the SQL Server package as a feature-based prerequisite
- go to "Organization" page, select the feature of the added prerequisite and from the "Feature Properties" right pane enable the "Install based on condition" option with the following condition:
PREQ
- select the feature of your application and from the "Feature Properties" right pane enable the "Install based on condition" option with the following condition:
APP
- go to "SQL Scripts" page and add the following condition for your SQL Connection:
SCRIPT
- go to "Custom Actions" page and add a "Test ODBC Connection" custom action without sequence
- go to "Dialogs" page and on your customization dialog select the SCRIPT checkbox and add the following published events:
  • Control Event: Set installer property value
    Property: [SqlConnectionString]
    Argument: Driver=[\{]SQL Server[\}];Server=[SERVER_PROP];Port=[PORT_PROP];Uid=[USERNAME_PROP];Pwd=[PASSWORD_PROP];
    Condition: SCRIPT
    Control Event: Execute custom action
    Argument: TestODBCConnection
    Condition: NOT (SqlConnectionString = "") AND SCRIPT
    Property: [PREQ]
    Argument: {}
    Condition: (SqlConnectionOK = "1" AND SCRIPT) OR (NOT SCRIPT)
    Property: [PREQ]
    Argument: checked
    Condition: SqlConnectionOK <> "1" AND SCRIPT
- build and run your project
Let us know if this helped.
