cainrandom
MSVS 2013 repair dialog with every MSI built
I get this whether building from the CLI or via the GUI, but here's the CLI output:
Building package (de): product.msi
Preparing files... done.
Creating CAB file(s)... done.
Creating MSI database... done.
Inserting CAB file(s) into MSI... done.
Writing Summary Information... done.
At that point in every generation of the language-specific MSI's, I get a Visual Studio dialog (see attached). I'm pretty sure it's the Visual Studio 2013 package self-repairing itself. It eventually goes away on its own, but it definitely slows down my build process.
Anybody else seeing this?
Re: MSVS 2013 repair dialog with every MSI built
Can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
Also you should take a look on the “Windows event viewer” log where you might see what is triggering the self-repair.
cainrandom
I was unable to reproduce this on a second build machine, so it's just something about that first machine's installation of VS. Thanks for the prompt response. I'll fix whatever it is.
McKool
I'm just experimenting the same behavior, but with Visual Studio 2012 (see picture). I first got this issue with AI version 10.7. I have updated to AI 10.7.1 but the issue is still there.
VS Problem
VS Problem
The project was actually not modified before and after the problem appeared the first time, only files where updated and the project was recompiled. Do you have any tip to resolve this?
Thanks in advance,
Keneth.
Hi Keneth,
Can you please try to test on another build machine and see if the behavior still persist?
Also you can take a look on the “Windows event viewer” log where you might see what is triggering the self-repair.
McKool
Hello Dan,
thanks for your reply. Checking more closer at the time when the window of visual studio appears I have noted that this happens while merge modules are added. (The issue happened between the steps with Text "Writing Summary Information" and "Adding merge modules". Those merge modules are also written/compiled with AI. They use a standard dll for custom actions which is written in Visual Studio 2008. Compiling the merge modules not shown any problem. Only when compiling the host installation (Mixed 32/64 bit, i.e. containing two merge modules).
I have started the compile process again and following information was included in the Windows Log (German):
  • Erkennung von Produkt "{93489CA8-6656-33A0-A5AC-E0EDEDB17C3E}", Feature "Visual_Studio_Professional_x86_enu" und Komponente "{480880B9-1E51-43EE-8CBE-5B448D59B5C7}" fehlgeschlagen.
  • Erkennung von Produkt "{93489CA8-6656-33A0-A5AC-E0EDEDB17C3E}" und Feature "Visual_Studio_Professional_x86_enu" fehlgeschlagen beim Anfordern von Komponente "{FD153241-37EC-11D2-8892-00A0C981B015}".
  • Eine Windows Installer-Transaktion wird gestartet: {93489CA8-6656-33A0-A5AC-E0EDEDB17C3E}. Clientprozess-ID: 6456.
  • Product: Microsoft Visual Studio Professional 2012 -- Configuration completed successfully.
  • Das Produkt wurde durch Windows Installer neu konfiguriert. Produktname: Microsoft Visual Studio Professional 2012. Produktversion: 11.0.50727. Produktsprache: 1033. Hersteller: Microsoft Corporation. Erfolg- bzw. Fehlerstatus der neuen Konfiguration: 0.
Hi Keneth,
Can you please make sure that the related .msm which is referenced exists on the machine?
Also can you please give us more details about that .msm file and a test case scenario so we can investigate this?
McKool
Dan wrote:Can you please make sure that the related .msm which is referenced exists on the machine?
YES, definitely. The compiling process ends sucessfull and the resulting exe can be installed on different computers with different OS and platfforms. It works as it should. The merged drivers are also installed sucessfully.
Dan wrote:Also can you please give us more details about that .msm file and a test case scenario so we can investigate this?
About the msm(s):
We use the msms to install own drivers. The merge modules contain *.inf, *.cab, and *.sys files. An own written msi standard Dll is used for handling custom actions that install the drivers. The DLL is written using Visual Studio 2008. The msms are created using Advanced Installer too. Compiling the msms don't generate any issue.
About the Installation project:
This is a mixed 32/64 Bit project who contains two msms (driver installation for each plattform). Despite of the VS Issue the project compiling process finish sucessfully and the resulting exe work propertly. THe issue appears only at AI compile time.
I will try to generate a test project using the merge modules...
McKool
I have sent a demo project and files to your support email.
Thanks for looking at it,
Keneth.
Hi Keneth,
Unfortunately we cannot replicate this behavior, therefore I'm afraid we don't have a conclusive answer on what triggers the self-repair of the Microsoft Visual.
You can also take a look on the Problem with 8.4 forum thread which debates a similar issue.
jasoncd
I installed VS 2013 today and encountered the same problem. I used the same solution when I had this problem a few years ago (registering mergemod.dll):
http://www.advancedinstaller.com/forums ... =2&t=11145
I have several copies of this DLL, but just used the same one as before.
Is your machine clean too? As said before, we cannot replicate this behavior, therefore I'm afraid we don't have a conclusive answer on what triggers the self-repair of the Microsoft Visual.
Can you please check on a clean machine and see if the behavior still persist?
jasoncd
Sorry, didn't get a notification. No, this is not a clean machine. Everything was working fine, but this problem started up again today. I installed VS 2013 Update 4 last week, so that is likely what triggered it.
jasoncd
For anyone who finds this, the most recent dll's still work for fixing this:
regsvr32 /u "C:\Program Files (x86)\Windows Kits\8.1\bin\x86\mergemod.dll"
regsvr32 "C:\Program Files (x86)\Windows Kits\8.1\bin\x86\mergemod.dll"
