MagicB70
Exception Msi API 1627: LockPermissions.idt
I am getting the following error while building.
I am using version 8.1.3
[ DefaultBuild ]
Building package (en): C:\temp\setup.exe
Reusing archives from cache... done.
Creating MSI database... error.
Exception - Error calling Msi API: 1627 Method: MsiDatabaseImport 1: 2216 2: C:\temp\setup.msi 3: LockPermissions.idt 4: 5 Table: LockPermissions.
How can this problem be solved.
Re: Exception Msi API 1627: LockPermissions.idt
Can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it?
