toschlog
Custom banner wrong in bootstrapper dialog
I've added a custom banner to my installer and it's not working correctly on the bookstrapper's prerequisites screen.
My image is bigger (1000 x 120) than the default image so it looks better if the user has larger font size selected. I have it set to scale so it looks right in the MSI dialogs. But it's not scaling correctly in the bootstrapper prerequisites dialog.
Attached are two images, showing the correct and incorrect dialogs.
Thanks.
This is the bootstrapper prerequisites dialog with the banner drawn improperly.
This is an MSI dialog showing the banner properly stretched.
Re: Custom banner wrong in bootstrapper dialog
I tested your scenario, but I cannot reproduce the behavior. Can you please tell us the version of Advanced Installer and also a step by step test case scenario so we can try to reproduce and investigate the problem?
toschlog
I'm using version 10.6. (I tried upgrading to 10.7 but I got a SignTool error.)
I've uploaded the AIP, prereq, and banner files that are causing this problem.
BannerProblemProject.zip
Project file to replicate banner problem
(686.51 KiB) Downloaded 534 times
This seems to be an Advanced Installer issue. Please give us some time to investigate this and we'll get back to you as soon as we have a conclusive answer.
Indeed, the "Prerequisites" dialog's banner seems to have problems when a BMP image is used, however it works when a JPG image is used. Can you try to convert your image and see if it works for you, too?
A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
You can see a response on the Message:SignTool Error: Invalid options: /fd thread about the signing problem.
toschlog
Yep, switching to jpg files fixed the problem. Thanks!
