litu
IIS 6 permissions
I need to change the IIS permissions on some virtual folders. In IIS 7, we have webconfig to do that; but in IIS 6 we have to do it in the IIS manager window.
There's any way to do that in AI?
Thanks in advance.
Arnau.
mihai.petcu
Re: IIS 6 permissions
Hi Arnau,
You can use Access Flags view to set those options for a virtual directory that is installed by the package. If you are trying to set them on an already installed virtual directory, there's no predefined functionality for that unfortunately.
